Mach3 Simulation Mode? - Remove Parll Driver?
countryguy
May 7, 2014
776
In the note below (which is older)- There is a comment to remove the parallel driver? I really want to run a few simulations before I run a larger Plasma CNC job. This would also be sort of cool for the Hobby Mill on some items. Anyone know if there is another way in Mach3? If not, where do I remove the Parallel port driver?
use Mach3 in Simulation mode – it will remove the 500 line limit. Simulation mode can be accessed by uninstalling (or not installing) the Parallel Port Driver.
Thanks everyone,
CG
Try Function Configs, Reset Device Selection
EDIT: Nope that didn't work.
Go to your Device Manager and Disable the Mach3 Pulse Engine driver
Also check out the program CNC Simulator Pro. It is free to use with some fairly minor restrictions and I have found it to be a pretty good simulator. I used it for all programs that I developed until I moved to BobCad and now use the built in simulator there.
Hi everyone, Thanks for the tips! Jim, That worked, but the CandCNC mach 3 customization for plasma caused issues in Z. So I uninstalled and reinstalled plain MAch3 in plasma mode. Disabled the Service - Boom. all good. I got what I needed. The kid has some plates to cut and then we're off to the new Mill! Cross those fingers. :) Jeff and Mitch.
