Voda,
I've never actually seen a 101.21400 or 618 but although in the parts manuals they call the M6-89 collar to the left of the small spindle gear a Spacer instead of a Collar, I assume that it must have set screws in it. If so, loosen those set screw as well as the one in the bull gear and you should be able to slide small gear, cone pulley, and bull gear a little bit to the left, probably enough to see in between the bull gear and the headstock casting.
To put everything back if you aren't going to pull the spindle, slide the M6-89 spacer (collar) as far to the right as the step in the spindle will allow and tighten the set screws. Pull out the direct drive pin from the right side of the bull gear and slide the bull gear firmly against the cone pulley, turn loose of the bull gear and tighten the set screw in the bull gear. After tightening the set screw, confirm that the pulley and small gear are free to rotate. There should be about 0.002" to 0.005" of end float in the pulley. If not, loosen the bull gear set screw and try again. When the end float is OK, re-engage the direct drive pin.
If you haven't ever done it, procedure for oiling the cone pulley bushings is as follows. Pull out the direct drive pin in the side of the bull gear. Rotate the pulley until you can see the oil filler plug (looks like a set screw) in the bottom of one of the pulley grooves, remove the plug and squirt some SAE 20 oil into the hole. Reinstall the plug. confirm that the direct drive pin is still out, engage back gear, and run the motor for 10 or 15 seconds. Turn off the motor and repeat the oiling steps twice more. Disengage back gear, align the hole in the pulley with the direct drive pin, and slide the pin in.
