- Nov 3, 2012
- 126
I'm working slowly at bringing up my first mill, and round-ram M-head from 1942. Hope I'm not asking questions already much-discussed.
Does anybody see this head casting as repairable?
I've read that the heads were individually fitted to the quills. This makes me hesitate to buy a head casting, for concern about the fit with my quill. Can anyone advise on this? What clearances did Bridgeport use?
I'm planning to use sealed, grease lubed bearings on the pulley and he upper spindle, and rather ordinary angular contact bearings (7205Bs) at the bottom, possibly drilling a hole in the quill for greasing. (I know the original lower bearings were side loaded 6205s, but....) Does this seem reasonable? I don't like the mess of the original oiling system. In any case, how do I arrive at the right preload for the lower bearings?
These heads were apparently designed for 3L (FHP) belts. These have pretty limited capacity and I would expect them to slip pretty readily on the smaller sheaves. There are several other belt sections that might work, available in raw-edge, cogged style: M10, XPS, and VX (in increasing order of section depth). Can anyone share experience with belts?
I saw a post mentioning, but not going into details on, approaches to damping out rattle between the spindle splines and the drive hub. Any pointers on this? I've thought of using some semi-hard plastic shims but not sure how to keep them in place....
Thanks for any guidance.
