- Oct 4, 2016
- 7,164
The bending die I made for my gaff project covers all of the deck holes of the Di-Acro bender. I had to add a capture plate to the die to hold the end of the 1/2" rod, then by guess, and by God locate a hole for a dowel pin. I made my own transfer punch locator from a sharpened cut off bolt put in the dowel pin hole, then optical center punched the small dimple, drilled under size, and reamed the hole. All of the stacked tolerances added up to it fit perfect. You could have just knocked me over with a feather.
