Spindle oil is not something to be increasing the viscosity of, may cause excessive heating and bearing failure. Use the correct spindle oil recommended bu the manufacturer; in the case of waylube, ditto. Years ago, STP was the big thing, this is just more snake oil.Been adding a couple ounces to spindle and way lube squirt guns. Spindle doesn't puddle as much.
