- Feb 17, 2013
- 336
I've been considering buying an indexer to use when milling some of the tools I've been making. It's a pain in the butt to mill a hexagaon with just a vise. I'm new to machining and don't have too many accessories yet and the budget to buy new stuff is pretty thin. I decided to try and build one using parts I had around already. I bought a used 5" chuck at a garage sale along with a Starrett Last Word indicator for the bargain price of $50 for both. I already had a good 12" brake rotor and hub and bearing assembly that was supposed to be for a buddies Impala but he sold it before I could get the new parts installed. He didn't want the parts back so they got used for this project.
I chucked the rotor in the lathe and opened up the center to fit the back side of the bearing/hub. The plan is to use the rotor as a base for the bearing/hub. After the center hole in the rotor was bored to size I marked and drilled holes in the face of the rotor to fit the 3 hole bolt pattern on the hub.
I mounted the hub on the rotor and locked it with a through bolt to prevent the hub from turning while I milled off the flange. I made three 8mm pointed studs from some old set screws and threaded them into the mounting holes on the back of the chuck. I set the chuck on the hub and used a dial indicator to carefully first level it then center it on the hub. Then I marked and drilled the 3 holes in the face of the hub to mount the chuck to it. I drilled the holes a little over 8mm to allow adjustment for final centering of the chuck. I found a PDF image on the net for a degree wheel and resized it to 5.6" diameter to fit the flange of the hub, then I laminated it in plastic at work. I punched holes in the degree wheel to match the mounting holes for the chuck. After I got the chuck mounted and centered within .001"
