- May 7, 2014
- 776
Morning all. Nice to be back home! Back to the YCM-30 and conversion from 80's CNC to a newer setup.
Step 1) I need to find .375 hollow shaft quad/diff Line driver (+5v) style. Not much luck in a cost effective line unless you know of something?
Step 2) the automation direct is hollow shaft or solid. I could do .375 solid and then just use a female to female .375 to join them. Also finding they are all 6mm to 8mm will need to join thse to my shaft.... Anyway--- Easy stuff there....
LINKS:
A) http://ecatalog.dynapar.com/downloads/F18_DS_702368_2_B.pdf
http://www.ajaxcnc.com/wp-content/uploads/2011/07/comp_encoder_large.jpg
B) http://www.automationdirect.com/static/specs/encoderld.pdf
Step 3) electrically, Anyone see any major diff w/ the automationdirect Item -vs- the dynapar F18. The electrical output of the F18 is twisted pair on a 16pin sip... -vs- 9pin on the ad unit. I'll need to check what connects up to the ajaxbox but I think it's only 1 line of the twisted pair ( they use the F18 and it's cost is $$2x more than the ad unit.) trying to move the costs downwards if possible. It's $375 in savings if I can sub the encoder to under $100.
LINKS:
