I'm not sure if this post is acceptable here or not, if it is not please feel to delete it. I know that this should be in the other machining forum but when I tried to post there in the past I was basically told that I was not worthy. This forum is much friendlier. With that said, I was tasked with purchasing new lathe for our shop at work. I along with one other mechanic will be the primary users of this machine. At the moment we have a Jet 1440 with some letters after the numbers, it also has a 3" bore and a gap bed. This lathe has been crashed a few times and has had some major repairs done in the past but now it is making more noises than usual added to all the other issues it has. The machine get used probably two hours a day on average with some days it will be running for most of the day. The size of the machine we currently have is about ideal for our needs, larger would be okay but smaller would cause some issues. So I'm not sure if we should be getting pricing on rebuilding our current machine or just or just purchase a new machine. From the little research I have done so far It would cost close to $20K to replace what we have with the same brand. Are there other brands I should be looking at that are higher quality/better value? I still have a lot of research to do but I thought I would through this out here.
