I need to build or print a 10-1572 that would work on an Atlas 10d. I have every other part to use the quick change gears. If I had an accurate drawing I could make it or if someone has done a cad file for 3d printing I could print it.
Clausing responded in under an hour with a .tiff of the original hand drawn draft from 1951. Now I just need to sit down and recreate it in CAD so I can print one to get me up and running before I buy a hunk of steel to start machining it. I figure a printed part should work for a while.
3D model is done and a test print has been completed to do some testing. Will print again at 100% infil and will use hot press brass inserts for all the treded holes. The drawing from Clausing was all I needed to get this done.
