- Aug 3, 2017
- 2,437
I've got a Montgomery Ward version of a Logan 10" lathe. Last night, I was cutting 20 TPI threads in some brass (1/4-20). According to pg 8 here (http://vintagemachinery.org/pubs/2093/3353.pdf), I shouldn't have had to pay attention to the threading dial at all!
However, I found that if I didn't line up to the numbered hashes, that I was getting a 2nd set of threads cut! Am I misunderstanding the text there, or did I do something wrong?
Additionally (hopefully not important), I recently took the apron apart in order to install the power-cross-feed mechanism. I had to take the half-nut out in order to do this, but didn't mark a top/bottom. I'm unsure if I got it on in the correct direction. I DID notice that when engaging the half nut, it didn't engage until about 10 degrees past the hash mark (similar to the image in Figure 10 of the above page 8). Could I have messed up doing that?
Thanks in advance!
Thanks in advance!
