- Apr 13, 2014
- 82
I recently acquired a Logan 1957 lathe, S/N 64747, that has had the QCGB gutted and a direct drive DC gear motor used in place. In an effort to bring it back to a place where I can use for threading operations I have been in the search for gearboxes and the drive train to power it. I bought a complete gearbox from a Logan 816 as well as the banjo bracket. I also have the reverse drive assembly in route but haven't received it yet. There are still some other parts to fill in the gaps to complete the project that I have yet to lay my hands on. My quandary is: There are some differences in the two gearbox castings, size wise as well as diameters for shafts, some are bushed, some are not.
1. My 1957 gearbox is a LA-1201 casting, the 816 is not.
2. When I lay out all the gear train for the lead screw speeds I have a .5 inch gap in the 1957 that I don't in the 816.
The selector levers will fit and the shaft lines up as it should. Edit:Upon further investigation I'm not so sure...
Bottom line, Am I going to get this to work or did I buy the wrong gear box? Thanks for your help in advance and God bless.
Jon In Tucson
Jon In Tucson
