The original instruction manual came with my Logan 816, and the lubrication diagram drawing indicates six oil cups that don't exist on my machine. 1 and 2 are oil cups on the countershaft bearings; mine has only small unthreaded holes there (I put a drop of oil in there every time I use it). 4, 6, 7, 8 are supposed to be on the QCGB to lube the headstock end of the lead screw and the QCGB bearings. There are no cups there (there is one on the tailstock end of the leadscrew). Interestingly, there is a photo in the manual of an 820, which appears to have the same gearbox as on mine, with no oil cups. Browsing here, I see photos of machines with and without the oil cups, so I'm sure I have an original QCGB.
Was curious to know if anyone knew why Logan did this, but more importantly, how should I ensure proper lubrication for the lead screw and the gearbox shafts? I've been squirting some oil where they attach, most of which runs off, and I stick the oil can nozzle into the change gear knob holes to get some on the gears, which also makes a puddle. Thanks for any insights!
