- Sep 11, 2020
- 1
Hello!
First time poster here, I recently purchased a Logan 1875 lathe and am giving it a much needed clean, but I ham having trouble removing the lead screw from the compound. I have tried extending and retracting it fully with no luck. I have taken off the hand wheel and all accompanying nuts, the dial, and the gib. Am I missing anything?
One other disassembly issue is with one of the 3-jaw chucks that came with the lathe. I was able to open the back, but I was unable to figure out how the driving gears are removed so I can finish taking it apart. Each gear seems to have a set screw with a long smooth shaft at the end, once I removed that the gears could wiggle a bit but would not come out.
Any help/ideas would be greatly appreciated!
