Logan 9B - 17 Parts
Alberg30
Oct 17, 2021
25
Im looking for Logan 9B parts, I am sure there are parts out there, I just need to find them.
Gear Cover that goes on the left side of the machine.
Two gears for the QCGB.......A compound Gear and the gear on one of the gear selection levers.
The bracket that holds the motor and the drive pulleys.
Large pulley that the motor drives along with the shaft and the stepped V belt pulleys.
Knob for the power feed.
Hello All, My logan Lathe, 9B -17 -1 has a serial number of 71848. Is there anyone here that may have an idea what year the machine was built based on the serial number? I have looked all over the web but found nothing.
Any info will be appreciated.
Contact Scott at http://www.lathe.com/
Scott is an honest man.
His parts are not cheap, but if he says they will work then they will work.
Additionally, he will likely be able to answer you questions about the lineage of your lathe.
Daryl
MN
