I'm currently attempting to install the DRO I got from the UK (links in another post). I got the Y axis installed and moved on to the X axis.
Turns out (as with my LMS 3960) you have to remove the saddle to drill 2 holes for the read head attachment plate. WARNING Will Smith!! It turns out the saddle lead screw nut is not only bolted to it, but is also PINNED. Not a bad idea - unless your mill is bolted to the table... Also the pins are very long and even though the Y-Nut dropped off as soon as I loosened the to socket-head screws - the pins remain, and are so long they prevent the saddle from sliding off from the front. This strikes me as a moderate design flaw as the mill should NOT have to be turned upside down to remove the saddle. Sheesh!
To properly unpin the saddle you have to turn (all 210 lbs!) the mill on it's side and drive the pins out from below. This was just not an option for me as I couldn't turn the mill over even if it wasn't bolted to the table.
So I drilled them out and will now have will have a bit of an extra chore when I re-assemble.
