Hi beone here.
Been cinching for bout 8 years. Have a home built router and a semi finished mill(operational, but if you build it yourself is it ever really finished) . Router has a xylotex 3 axis and the mill has a G540. Currently both running Mach3. Primarily use Vcarve for cam.
Was recently given 4 old computers, and find they all run well on Linuxcnc, which is Ubuntu. Trying out the cnc, not hooked to machine yet, I kind of like what I see but can't find the answer to one question in the docs.
I currently have the Vcarve set up to create .tap files for both, no probs in many years. The Linuxcnc seems to insist on a .ngc file? Is there a way to change the Linuxcnc to a .tap? I don't want to change anything on the router as it is stable, am experimenting with the mill, and would prefer one instance of Vcarve. I assume it's a setting somewhere but I haven't found it. Any help will be appreciated.
PS. Vcarve seems or run fine in Wine.
Dave
Dave
