I have a new Sieg Runmaster 330x1000 lathe that I wish to level. It has 4 adjustable legs (16mm Cap Bolts) sitting on 4 hockey pucks under the head stock end of the stand and a pair of similar legs under the tailstock end of the stand.
My approach would be to retract one pair of the legs under the headstock end and level the lathe end for end and across the ways at headstock and tailstock in the normal manner using just four legs initially.
Can anybody advise
1 Would it be better to use the inner or outer pair of legs under the headstock for the first levelling?
and
2 How would you then adjust the second pair of legs under the headstock to get the same load on all four headstock legs?
Thanks
Ron
Can anybody advise
and
Thanks
Ron
