- Nov 13, 2020
- 15
I have a Baileigh PL-1022VS (not the newer revision 2 they have under the same model #) that's seems virtually the same as Quinn's Precision Matthews lathe (at least the casting and a lot of parts are the same) from Blondihacks, so I've been following her video on leveling the lathe:
I got the bubble as close as I could using her method with two parallels, and now I'm cutting the test bar, I am getting pretty close by shimming the front left (the leg under the headstock closest to you when standing at the lathe), but a thought came into my head. How do I know if I should be shimming the front left leg or the back right leg? So I put my level on the cross slide and ran the carriage from left to right and the bubble stayed in largely the same spot in various positions along the bed: https://www.icloud.com/photos/#/icloudlinks/002DGEb_wo7ZsPbDt314lzJmA/
My first question: is putting the level on the cross-slide and moving across like I described above kosher? In my head it seems like it should be, since I'm just checking the relative position of the bubble at various positions along the Z axis?
If it is, this leads my to my second question, which is, if the bubble is the same across the length of the bed, wouldn't that indicate that the spindle/chuck are not perpendicular to the Z axis and need to be adjusted, instead of me continuing to shim the legs? If not, how do I know if I should shim the back right or front left leg? I assume the bubble would tell me since it would tell me if there is twist in the ways?
