- Jul 1, 2012
- 1,356
Here is the instructions I told you about on How to level and align a lathe. If you do not have a precision level use the 2 collar test.
These instructions are for a large heavy casting machine, but the principal is the same for a small mini machine. If it is bolted to a bench, shim between the bed and table. Read the 2 collar test last. They attached on here backwards. View attachment LatheLevelingand2collartest.pdfView attachment LatheLevelingvsAlignmenttest.pdf
