- Dec 18, 2019
- 7,063
So I took home a sundial from my mother's house. It's literally a garden variety cast iron sundial. I kept on staring at it, trying to figure it out. No matter what orientation I moved it, it seemed wrong. Well, today I looked up sundials on Wikipedia and discovered it was manufactured incorrectly.
https://en.wikipedia.org/wiki/Sundial
There's two things wrong, one: the gnomon angle should be angled at one's latitude, and two: the gnomon was attached to the base backwards! Now I could have forgiven the first, but really now, this gnomon was installed 180 degrees from where it should have been! So it never could show the time. I find it hard to believe that this junk gets sold to people. So I'm wondering if I can somehow fix it.
The Roman numeral XII should be on the same side as the right most tip of the gnomon. As is, it won't show the right time ever, anywhere on earth. The gnomon tip should point to true north (since I'm in the northern hemisphere). I'm at 42.76N, I figure 43 degrees is fine. I put a 45 degree reference next to the gnomon and it's much steeper than that. I'll measure it after I bring it inside. I don't know guys, but this kind of stuff just irks me. Installing the gnomon backwards, gosh, I'm having problems with that... I'll probably blast off the paint later and redo that, but first I need to see how to remove the gnomon.
