[TABLE="width: 100%"]
[TR]
[TD="width: 85%"]I need to make a jack-shaft assembly to mount a pulley on for some gear reduction. I was looking at mounted bearings like this for a starting point.
I am wondering if I can just mount one of these solid with a 4-5" shaft coming out of it that I can put a step pulley on.
I know it would be better supported if I had one on each side of the shaft. But I see lots of jackshafts like this so I am thinking it must be possible. I am thinking that if the dynamic load rating of the bearing was not exceeded by the pressure of the belts I should be good to go right?
I could also do two of these
but I think it would just be more expense and less simple.
What do you guys think? :thinking:
[/TD]
[/TR]
[TR]
[TD="class: smalltext, width: 85%"][TABLE="width: 100%"]
[TR]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[TR]
[/TD]
[/TR]
[TR]
[TR]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
