My thinking after reading thru this thread is as follows.
If steel rusts due to oxygen and a catalic (water usually) will steel rust if there is just oxygen and no water?
So, if the air in the tank is dry, there should be little concern about leaving the tank pressurized. But, if there is water in the tank, it could then accelerate the rusting process.
Now, as to wether it is good to leave pressure in tanks, it probably is from the standpoint of not allowing atmosphere air, with humidity into the tanks. This is more app to high pressure tanks like Oxygen and other welding gas tanks. If the valves are left open to the atmosphere when emptied, then other contaminants can get into the tank, and effect the usage of said gases when refilled, if the tank is not properly cleaned/ purged when refilled.
I knew guys that would be so cheap, they would bleed all the gas out, just so the gas supply shop would not get any bonus gas back. Little did he know that it really cost him more in the long run, especially when he had a contaminated tank come back to him that might not have shown any problems til only a couple PSI left in tank.
And I have experienced bad gas in argon tanks before when running low. Welds turned crappy, even though couple hundred PSI left. Change tank out, and problems go away.
