The older I get the more I have learned to laugh at my mistakes and the learning moments life sends my way.
Full disclosure here, I have had my 70 year old lathe and milling machine for more than a year now but I have not actually made many items and none that require great accuracy. But no problem, I have watched enough YouTube videos to get my doctorate. So when a good friend asked me to make a shell reloading " holder" for his large hunting rifle I said I would give it a try. He also sent along a price of mystery metal to use for the project.
He gave me an example for a smaller shell holder that gave me the dimensions and from the feel of how the shell fits into the holder there was not a need for extremely close tolerances.
Being the good friend I am I decided I would upgrade the steel a bit to W1 tool steel since I had not had a chance to work with that yet. I knew from videos it would be harder to machine but I have some carbide inserts on the lathe, and I'll take small cuts.
Second, I knew the slot for the "rim" of the shell to slide into was fairly critical and I did not trust my ability to grind an internal grove tool and accurately measure the inside circumference, no problem, I'll just make it in two pieces and fuse them together with TIG. I know, I know, I'll let it cool slowly so it doesn't get too hard. And I'll make a small shaft with both diameters to properly align the two prices.
So I learned a few things making this...
I learned my 70 year old lathe can create " cut off" chatter so loud it will loosen dental fillings.
I learned to crate a finish that looks a lot like knurling with that chattering cut off tool.
I learned hss endmills do not like hardened tool steel from welding. So if you dull one, try a new one so that dulls too.
I learned that I should have annealed the piece rather than using hand grinders, when the end mills crapped out, I re-learned not to forget the "file test" before trying to machine.
I leaned that patience is a virtue and that if I had some it would offset my stubborn Dutch sole that I have to just finish the damn thing no matter what it looks like.
I learned that I am still a complete nuub and will be for some time. YouTube cannot fix that. YouTube has helped a lot but not a replacement for experience.
I also learned that I'm still smiling, I didn't loose any blood and only a little treasure from the lost end mills. Im getting a little better each time i try something new.
I don't even know if the part works yet since I haven't yet delivered it back to my friend. And I just realized that in making such an ugly part even if it doesn't work, I'm not likely to get asked to make it again.
So I just thought I would share this with you other really new to machining folks out there so we can laugh and learn together.
John in Minnesota.
John in Minnesota.
