- Dec 31, 2010
- 937
I have a small Atlas horizontal mill that is new to me that I have completed some very simple work on. Now I want to make "T" nuts using two cutters. The spindle shaft is 7/8' and the ID of my cutters is 1.000" At this point I am making a spacer to hold the cutting discs approximately 9/16" apart for the1/2" "T" nuts. After the spacer will come some bushings for the cutter discs at very tight tolerances.
I have set the compound slide on my Enco lathe at 5` which I believe will let me cut approximately 0.001" when I turn the leadscrew 0.010" . The mill vise will have to be dialed in to be parallel with the table movement. At this point I should mention my S I L brought out some aluminum 1/2" "T" nuts that someone had started but need the shoulders cut on them. Clamping them in the vice seems logical and I want to hold them down with a short bar between the cutters. Obviously a shim about 5/8" thick will have to be under the nuts Hopefully a recess in the hold down bar will prevent end movement. Now if the weather warms up some I think I can get these nuts made.
Have a good day
Ray
Have a good day
Ray
