- Aug 22, 2012
- 4,271
I needed to transfer some holes in two pieces of stainless sheet so I placed the two disks together then to align the holes I used a length of 8mm stainless rod held in the drill chuck and set it in the top hole then clamped it all to the drill press table.
Upon rotating the drill the rod prescribed a circle, I thought there must be bend in the rod so I quickly cut another, same problem.
Argh, my reasonable new drill press is wearing already???. Possible 0.5mm out
Nope!
I tightened the chuck with the key in one hole only as I always do then for some reason I tried using all three holes and gradually tightened the chuck.
Bingo, the rod is now perfectly centred.
I guess this is how I will tighten drills in the chuck from now on.
Nope!
