- Jan 26, 2011
- 632
Mike,
Show us a pic of the QCGB, it should be a double tumbler gear box. It is a tight fit in the bearing and should move as long as the leadscrew turns. Wiggle the leadscrew while pulling the leadscrew out. If that don't work get a small ceramic heater and let it heat up the case then try. If you are going to take it all apart watch out for the taper pins and make sure they are facing the right way before hitting them out. My gearbox was frozen when I got it and had to use heat from the little heater to move the shafts so I could get the taper pins headed in the right direction. The gear box is the hardest part of the lathe to work on, so take your time.
Paul
Paul
