Lead screw support bearing repair.
LX Kid
H-M Supporter - Gold Member
May 26, 2015
875
Crafty 12x42 lead screw support bearing broke from lock up of the apron mitre gear. They are designed to break when things go wrong to keep from ruining gears. I had a spare bearing and lathe is up and running again after doing shim adjustment on the mitre gear. Now I'm trying to do a repair for a backup. I'm not much for aluminum welding so I elected to try epoxy repair. After taking measurements and propping in place I epoxy it together. Now gotta wait 24 hours for full cure. Don't see why this wouldn't work just as well as a backup. Have a new one on order.
Chances of epoxy working well are between slim and none, with failure resulting in a spoiled job.
Your probably right but it is a backup to another one that's on order. Maybe a tie wrap around it for extra support might help! LoL
Seeing that picture, I'd be more worried about a bent lead screw! 0% chance of the epoxy holding.
The ones on the Atlas lathes that this appears to be copied from were made of z-Mac a zinc alloy ; not very strong. They are known to break easily. It was broken on the lathe I bought. Replacement was made of block of aluminum.
The design of the right lead screw support bearing was to break in case of a jam or crash at the headstock end. Whenever this happens, the lead screw is supposed to eject itself from the headstock, disabling the carriage drive and cross-feed drive.
I have never had the guts nor the misfortune to test it but at least in theory it should work as planned.
