Lathe Tool Bits
JLMullins
Apr 10, 2016
7
I am brand new to this. I bought a mini lathe from Harbor Freight #93212. I am try to figure out what tool bits to use for what. I see different type during searches but can't find an explanation of their use. Does some one have a link to a page that shows the different bits to use. I got some bit at Harbor Freight they are carbide but not the indexable type. Does someone have pics with explanations of what each bit is used for?
Thanks,
Jimmy
Something like this, you mean?
I just did a quick google image search using "lathe tool profiles" as the search criteria, lots of pics come up. There's also good info in both the Southbend and Atlas lathe manuals if you have copies of them. You should get at least one of those manuals anyway if you're just getting going on using a lathe. Extremely beneficial.
-frank
You'll find out very quickly you're going to be grinding a lot of different profiles for different work. The chart Francist posted if only the start :) Stock up on HSS blanks if you can. Believe it or not some Harbor Freight stores carry HSS blanks in their stores. 5 tool bits for $5. Can't go wrong.
Use a tool that will accomplish the work needed, the only requirement is that it works for the intended application, for example there is no reason not to use a "TSC" shaped tool upside down running the spindle in reverse if that is all that you have and it works.
Thanks, what these different type of tools used for that I got at harbor freight? I can't seem to figure out what shape does what and what the A,B,C,D,E= (60 deg Thread I believe). I know the L&R is left and right.
Thanks I bought a bunch of HHS blanks. Just need to learn the shape to grind them to and the angles.
-frank
Thanks, are these manuals online?
-frank
Is the something that explains the letters associated with the image you included?
OK here I found something I hope will help. What is each of the type tool bits used for? Is there a place on the internet I can find this info?
Thanks,
Jimmy
Type AR883 0° Side Cutting Edge Angle- C2 Carbide
Type AR370 0° Side Cutting Edge Angle- C5 Carbide
Type AL883 15° Side Cutting Edge Angle - C2 Carbide
Type AL370 15° Side Cutting Edge Angle - C5 Carbide
Type BL883 0° Side Cutting Edge Angle - C2 Carbide
Type BL370 0° Side Cutting Edge Angle - C5 Carbide
Type C883 0° Square Nose - C2 Carbide
Type C370 0° Square Nose - C5 Carbide
Type D883 40° Side Cutting Edge Angle - C2 Carbide
Type D370 40° Side Cutting Edge Angle - C5 Carbide
Type E883 60° Included Angle - C2 Carbide
Type E370 60° Included Angle - C5 Carbide
Type ER883 30° Side Cutting Edge Angle - C2 Carbide
Type ER370 30° Side Cutting Edge Angle - C5 Carbide
Type EL883 30° Side Cutting Edge Angle - C2 Carbide
Type EL370 30° Side Cutting Edge Angle - C5 Carbide
Type FR883 0° End Cutting Edge Angle - C2 Carbide
Type FR370 0° End Cutting Edge Angle - C5 Carbide
Type FL883 0° End Cutting Edge Angle - C2 Carbide
Type FL370 0° End Cutting Edge Angle - C5 Carbide
Type GR883 0° Side Cutting Edge Angle - C2 Carbide
Type GR370 0° Side Cutting Edge Angle - C5 Carbide
Type GL883 0° Side Cutting Edge Angle - C2 Carbide
Type GL370 0° Side Cutting Edge Angle - C5 Carbide
Carbide Tipped Brazed Boring Tools
Type TSA883 TSA Square Shank - C2 Carbide
Type TSA370 TSA Square Shank - C5 Carbide
Type TSC883 TSC Square Shank - C2 Carbide
Type TSC370 TSC Square Shank - C5 Carbide
Type TSE883 TSE Square Shank - C2 Carbide
Type TSE370 TSE Square Shank - C5 Carbide
Type TRE883 TRE Round Shank - C2 Carbide
Type TRE370 TRE Round Shank - C5 Carbide
Type TRG883 TRG Round Shank - C2 Carbide
Type TRG370 TRG Round Shank - C5 Carbide
Standard Cut-Off Tools
Type CT883 C2 Carbide
Type CT370 C5 Carbide
Type CTL883 C2 Carbide
Type CTL370 C5 Carbide
S.A. Series Swiss Automatic Tools
Type SA-C C2 Carbide
Type SA-T C2 Carbide
Discount-Tools.com - Quality Cutting Tools For Less!
Customer Service 1-877-848-8665
General Information: info@discount-tools.com
Sales Questions or Quotes: sales@discount-tools.com
Bench grinder for roughing and an oilstone for honing are all you really need, many different types of angles and grinds to experiment with.
