Lathe splash guard surround DIY?
umnik
Jan 26, 2017
67
Most of modern new lathes comes with splash guard surround. I got old used lathe which does not have one from the beginning, so I want to make it.
Did anybody make one? I'd like to get some inspirational pictures and which material to use and where to get one from?
I made one for my lathe. Constructed a frame from steel angle then attached aluminum panels with screws. Constructed a couple of shelves as part of the framework and used expanded metal for the shelf surfaces. Also included a fluorescent lamp. Photos attached.
Ted
Ted, that is very neat set up. I am impressed, will keep in mind for my design.
Here is how I did mine.
Ted
View attachment 302638View attachment 302641View attachment 302640
Very very nicely done. I like the lighting idea for extra light. I suppose the aluminum helps alot with light reflection too? Really nice. I also like the covering behind the chuck,but is it not in the way when tightening and loosening?
Thanks for the kind words. You are correct about the light reflection. I constructed the plate behind the chuck and the two piece plexiglass door to help control coolant. Without these measures I always had an oil stripe up my chest as well as on the floor and ceiling. I made an extension about 8" long from 3/4" diameter CRS with a 5/8" hex on one end an a square drive on the other end to fit the D1 spindle cams so I can use a ratchet wrench with a 5/8 socket to install or remove chucks. Works out well.
Ted
