The lathe is a 1957 Clausing Colchester 13x36. The project is a 1/2 inch by 4 inch 'extension' to a worm gear. The first step is to create a cylinder to use as the blank for the part. I machined the cylinder blank and was surprised to find it had 5 thou taper. To check I placed a measured piece of drill rod in the lathe via a 5C collet and the tail stock. I then ran a dial indication along the horizontal axis from the head to the tail stock and measured both the rotaional and runout and the runout from moving the carrage. This showed about 5 tenths runout. Yet when I machined the part with the same setup there was 5 thou taper.
What is wrong with the measuring the technique?
If the technique is valid what is the source of the taper?
