- Jan 25, 2022
- 129
PM1130 lathe, a few years old and only hobbyist use.
Tracking down a long-standing carriage stiction issue, I disassembled the carriage assembly and removed the saddle. Not great machining in there, as expected.
What I noted was a narrow wear mark along the length of the V-groove on both sides. Very narrow is some locations, and a few skipped areas too. About half-way up each face, but this varies also.
You can see the corresponding markings on the ways V also, though this just polishing - no perceptible wear. The ways look good, straight and flat.
Using a straight edge on the faces (perpendicular to the groove), the high spots are obvious.
Info and photos from here and the 'net suggests these surfaces should be flat, 90-degrees, for maximum contact area with the ways. Correct?
I might try to correct this on the mill - an adventure Any suggestions?
Before I mess with this, might see if I can get a replacement saddle from PM -- in case I screw up this one.
K
K
