My 1946 vintage Southbend 9A lathe is the 6 speed version, which means its top speed is pretty low. I measured it at about 580 rpm. Since I typically machine aluminum and small stock that is 2" down to .375 in diameter, should I try and get an optional used dual pulley setup for the lathe that bumps its top speed to about 1200 rpm? Besides the work progress being slow at the lower rpm, am I hurting my finish going slow vs the faster cutting that aluminum will tolerate? The dual pulley setup is about $200 with shipping, and I need to get a new drive pulley for the motor and a belt. So figure $250 all said and done.
- Phil
- Phil
