http://bedair.org/Ball/ball1.html
I am currently making this one, if that is what you are looking to do.
Ever since I got my first mini lathe I've always wanted a ball turning attachment. So I decided to make one for my current lathe. Since I don't have a mill yet, I used an attachment that I got from the for a Myford that is based on Steve Bedair's ball turning tool post.
Here's how I did it (...lots of pics to follow!).
Here's what I started off with. The Myford attachment & a 5" dia 30lb piece of CR1018.
Mounted in the 4 jaw, making the base plate with this piece.
Cut off the base plate & save the rest for another project.
Cleaned it up, drilled a couple of holes, & test fit.
Bored out the recesses on the top of the base plate for the tool post.
Bored out the bottom of the base plate for the mounting/pivot screw.
Base plate is done, on to make the post assy. 3" dia 1018.
Machined the steps for the bottom of the tool post.
Bored out the recesses on the top off the tool post for the cutter assy. Drilled a hole all the way through for a M6 bolt, then tapped threads the bottom for a M10 bolt.
Tool post is done, time for a test fit.
Tested it out on a piece of alum. Ditched the insert & screw that it came with for a TNMG 331 Cermet insert & Ti flathead/countersunk type screw for better seating. Chatter free & right on center line!
Here's how I measured the cutter height.
Here is the top mating surface for the cutter assy.
Turned down a M6 bolt to fit through the M10 thread at the bottom of the tool post to bolt on the cutter assy.
The mating surfaces of the post & base plate. Since this is where I made the tool post pivot I added some lube.
The bottom of the base plate. This part is critical since the washer should only mate against the small step of the post that fits through the base plate. But if that step is too high you'll get unwanted play leading to chatter.
All assembled.
Time to give it a try, first up was a ball knob to replace the cheapo plastic one.
Threaded a rod & a piece of steel.
The rod I was using to hold the stock was too thin & chattered a lot so I had to switch to a thicker one. After a little bit of sanding I ended up with this.
Here's the new knob on the tool post.
Thanks for looking.
Does any one have ideas for a radius cutter?
