I have an Enco lathe (model 110-2031, of which I own possibly the only example), and I do not have the manual. I have been reading the manual for the Grizzly G9249, which is clearly somewhat similar, but definitely not the same. In the manual, in the section "Power Feed", is described the operation of the feed rod. I have a couple questions:
- I had been previously familiar with the lead screw, used for power feed (of the carriage) as well as threading operations. I wondered why it is necessary to have a second rod that performs nearly the same function (with the additional function of driving the power cross-feed). Wouldn't it be possible to eliminate the lead screw and use the power feed for threading?
- The manual is not entirely clear on whether I can engage the power feed (in either cross-feed or carriage-feed mode) while the machine is operating. It says not to "change gearing" while the machine is running, but under "to engage the feed rod", step one is to turn the spindle off, and step two is engage the feed rod (start the spindle isn't until step 5). Is it actually necessary to completely stop the spindle before engaging power feed, or is it like the half-nut where I can engage it while the spindle is running (assuming everything else is set correctly)?
- Is there any way to know what change gears I'm supposed to be using and what my feed rates would be based on the various quick-change settings? There's a table in the G9249 manual, but I don't know if it applies to my lathe. While there is a threading chart on the quick-change gearbox, there is no feed rate table there.
