I'm working on building a basic milling attachment for my leblond using a angle plate.
I'm going to put the angle plate on and attach my compound slide to do the vertical movement.
2 questions.
1. Are there any options for pre-built vises that would be easily adaptable to fit in the T-slot of the compound slide, or is this a role your own approach?
2. Every lathe picture I've ever seen shows the mounting surface of the compound slide to be flat all the way across, but mine has a relief in the middle of it. Is this normal? or did a past owner modify or have an unfortunate incident? Also, the relief sometimes causes me issues when positioning my CXA QCTP as I have to place it really close to the edge, or flat in the middle to get a solid mounting surface. Any ideas if there was a way to undo the relief?
2 questions.
