- Aug 20, 2024
- 21
So I have an 80's vintage Grizzly 12x24 belt drive lathe. I've had it about 15 years, circumstances were such that it hasn't seen much use in the last 10 or so. But circumstances have changed, and now I'm really focused on getting more serious about my machining hobby. In that vein, I recently installed a 3 phase motor and VFD, that went well other than needing new headstock bearings. After quite a bit of aggravation, I think I've finally got the bearings sorted out, it's now producing better results than it has for years. But it's been moved several times since I bought it, and it hasn't been leveled or aligned in a long time, so I figured it was overdue. Which brings me to today.
I've attempted to level this lathe several times since its last move, all to no avail. I end up chasing myself around in circles, finally giving up and putting my precision level back in its box and settling for "good enough" with my carpenter's level. Today was no different, other than the realization that I really have no idea of where to even start. Using the precision (.0005"/10") level, I get wildly inconsistent numbers between end to end, front to back, and carriage to ways. I think my problem is I don't have a clue as to what should be my initial reference point. I'm reasonably certain I'm dealing with both twist and wear in the ways, but with no idea of where to start, I'm just chasing my tail, and my puppy is far better at that than I am . I strongly suspect I'm missing something obvious here, I'm good at that, but if someone could point me in the direction of a good starting point, I'd sure appreciate it, thanks!
Dave
Dave
