Being a confirmed pack rat, I went ahead and brought that lathe home yesterday.
I finished tearing it down this morning and haven't found anything serious wrong with it or anything major missing. I've also been over it very thoroughly and can't find any identifying marks. Nothing cast into the bed, pan, legs, headstock or apron. No tags. Did find one 4 digit number stamped on the inside of the apron but that's it. No change gears and not seeing anything that looks like a provision for them, just forward/reverse idlers for the lead screw.
I'm thinking for a Winter project, I'll clean it up good, lube it and put it back together and see how it works. At the moment, all I have into it is a tank of gas. If cleaning and reassemby produces a working machine, I may go to the effort of stripping and painting.
I would like to thoroughly clean the headstock casting and belt pulleys and this leads me to a couple of questions:
First, it has bronze (I assume) bearing shells. There's a little scoring but nothing that I think will seriously affect running. I'd like to submerge the casting in some solvent to remove grease and loose paint but I'm concerned about damaging the bearings. I'm also loathe to remove them for fear of tweaking them out of shape or not being able to get them reinstalled properly. Which way should I go with that? Soak bearings and all or hope I can remove and reinstall them without tearing them up?
Second: If I remove the drive gear on the end of the spindle shaft, I can slide the belt pulleys off and clean them up properly. I can see that it's keyed to the shaft and I suspect I can just pull it with a gear puller but I'd appreciate an experienced opinion on that.
