Lathe hss bit grinding jig
Mike8623
Dec 18, 2013
607
Does anyone know of a simple homemade jig or fixture for grinding your lathe hss tool cutters. The simpler the better.
Are looking for an actual fixture or a gage to measure the tools ?
Looking for the plans or a picture of a fixture that will allow me to accurately grind the angles for lathe hss cutting bits. I've got items to measure angles. Looking for the simplest jig I can make.
I take it you have a surface grinder ? Most bits are simply ground by hand on a bench grinder or abrasive belt .
If you are looking for a "Jig" type of method to grind your HSS lathe bits, you might look into Tangential cutter bits. There are a number of designs out there that position the HHS in a jig that creates a Diamond faced cutter bit, which is then held in a tool holder that places the bit at a tangent with the work piece.
Here's a company that makes both the Grinding fixture and tool holder, but there are numerous diy designs floating out there on the web.
Hope this helps.
I thank you so much for your input
+1 on the Diamond Tool holders. The grinding jig that comes with them isn't a universal tool grinding jig, but rather
useful for the specific grind required by the Diamond. They are useful tools however: I use mine all the time.
