Hi,
being a newbie to the lathe, I have been trying various basic procedures to get to know how things work. I moved the top slide from the position it was in when I first got the lathe but now I need to reset it to make parallel cuts. As there are no angle marking on the top slide, setting it to cut exactly parallel seems to be a real pain. If i am only out by a very small amount the cut is either wide or narrow at the chuck end over a 4 inch test piece. Can anyone explain a quick and simple way to set the top slide to cut parallel without resorting to making a test cut every time the top slide is moved. The lathe has no manufacturers name on it but it looks like a 4.1/2" Warwick made around 1950.
Any help would be appreciated.
Warren
Warren
