Lathe Chip Pan Mess ?
randyc
Feb 5, 2015
662
This may be old news but could be of interest to those with anal obsessive-compulsive personalities like mine LOL :)
Chip pans on my lathes do what they are supposed to do: collecting chips and the fluids used in both the cutting process and the normal overflow from lubrication of the lathe (lubricants usually have no place to drain except the chip pan).
It’s not a big problem to clear out chips occasionally and then wipe down the chip pan to remove most of the fluids but it does take some time and the machine just looks “messy” in the meantime. Another option is to scatter a pound or two of kitty litter (cheap stuff) around the chip pans. This stuff absorbs cutting fluids and lubricants readily.
Occasionally, the litter can be re-arranged in the chip pan to expose new material in areas where fluids tend to concentrate. Chips are still scattered over the pan, of course. Most of my work involves working with steel and magnetic materials are easy to deal with. This is a tip that is well-known:
Insert a magnet inside a plastic grocery produce bag, a sandwich bag (or even a paper bag). Move the enclosed magnet over the chip pan and the chips will adhere to the outside of the plastic bag. Place the bag over a trash container and remove the magnet from the bag. The chips will fall into the trash container. The process can be repeated until the chip pan is as clean as you like.
(Non-ferrous chips are a different matter. This is a disadvantage when using kitty litter because your shop vac can’t suck up the aluminum chips without including the kitty litter. So chips must be removed by hand …)
Kitty litter absorbency seems to be adequate for several months before brushing it into the trash and adding a new layer.
I use a homemade Al tray that fits in the chip pan. Then just empty it into 5 gallon buckets for different metals.I just empty the Al tray when I turn different materials. Turned in 2 filled with brass and bronze and came away with a tidy sum of money. The scrap yard I deal with just dumps them in their bin and and gives me the going day rate of what ever metal I recycle.
**************Just Saying*******************************Gator*******************************
Very neat idea. I have used kitty litter as oil dry on concrete and to harden waste latex and oil based paints. Mix into paint and within a day or two it is hard and can be disposed of in the trash.
Good idea ! I rarely work with non-ferrous materials, too bad because there is a place in town that buys the stuff and it would be nice to recoup some of the price of the metal !
another thing to recycle is those used up carbides. That stuff brings a hefty price at recycling.
