Using Mr Pete's you tube video on this:
I happen to have a blank of both what I call tool steel or, I can use the other end of an HSS parting tool.
I tried it with a blank 3/32" HSS bit but it had WAY too much flex as it was pressed into the piece. And still not wide enough to make a 5mm keyslot.
I want to use the tool steel blank to make the cutter as it should have a lot more rigidity than the HSS.
The tool steel is super hard to my mind.
(Dont laugh.... )
I ground down an old Armstrong knurling tool clamping tang so it would fit into my Enco stock toolholder. It took FOREVER!!! But it also allowed me to creep up on the final grind dimensions. That old knurler looks pretty cool now too.
It also seems to me that this stuff is super rigid.
This is why I want to use this blank instead of the HSS one but, I have no idea if this will work for the cutter as I have never heard of this being done.
Can I use the Tool steel or should I stick with HSS for making the cutter?
(Dont laugh.... )
