Hi All,
I have been working on this for some time now and seem to finally be making some headway!
The bench i have my Myford mounted on is a rickety affair to say the least...
It was time for a change and a bench that did not want to walk around the shop!:biggrin:
So i set about building a strong and sturdy wooden bench!
Here it is painted and almost ready to go!
Shelves will be added at a later date to store the chucks on and accessories.
I was also thinking that i needed a nice solid base to mount the lathe onto.
Enter the concrete counter top!!!!
It is not done yet as i need to pour the base with some self levelling concrete still.
When complete it will be around 4 inches thick!
Once the base is poured and cured i will polish the top using a diamond disc in a wet sander that i have.
As a treat to myself and my wife i bought a small shop crane so that she does not have to help me carry or move
any heavy items anymore!!!
So the concrete counter will be mounted onto the wooden bench and the lathe bolted securely to the concrete.
Shimmed and levelled it should prove to be pretty stable!
If all goes according to plan i will be building another similar set up for my South Bend and the Sieg SX2L mill!
Then i will have a nice workshop to spend many hours in!:biggrin:
Oh and i also have to find a spot for the Taig lathe....
Andrew
Andrew
