Curious as to folks thoughts on how the lathe bed should be fastened to the cabinet. I've got a 12" Commercial, with the under cabinet motor. Presently, it's pretty much set up per the manual. Where the lathe bed is bolted to the frame, it is done with rubber washers sandwiched between the flat washers. Kinda wondering if it would be better to eliminate the rubber washers or not? I have the cabinet bolted down to the floor via concrete anchors, and wondering if that's really a good idea or not. Perhaps free standing on leveling feet is a better way to go? Thoughts?
