I am experiencing drift in the lateral position of the tailstock of my EMCO compact 8 bench lathe. The construction of the tailstock is very simple as shown in the exploded diagram. The lateral position of the tailstock is fixed by two set screws ( part 15 in the diagram ). After the position is adjusted, it would change over time by around a thou although both screws stayed very tight. I took it apart and noticed that the screws are not sitting on the entire surface of the end as shown in picture 3. Can that be the reason ? Are there any fix to the problem ?
