Posting here because I did not see a forum that seems to apply to this situation. I am thinking I'd like to have a laser engraver to mark drills, and mills, pin gauges, tools I make, etc. Some with very small print, smaller than I could do with my diamond tipped, hand held engraver.
I'd like to know if anyone here has experience with a solution for this and what recommendations they could provide. I'd like to learn the possibilities and requirements for this, like what is required to engrave tool steel.
The idea I have in my head is some king of small CNC unit where I would put my drills/endmills in a V-lock and the engraver would be able to put the size info on them. For instance, I'd like to put the size just above the flutes since I don't normally chuck there and it wouldn't get rubbed off, plus I am thinking the laser engraving should not rub off easily. I could be very wrong on this, and that's why I'm asking. In some cases I grind a special tool bit for a particular job and would like to mark it so I know what the tool bit is for so I don't regrind it for something else.
In my preliminary research on this it seems that metal engraving with a laser is not nearly as common as for softer materials.
Thanks,
Chris
Thanks,
Chris
