I've been messing with lasers for a while and wanted to buy a laser edge finder for my mini mill. They were kind of pricey, so I decided to make one myself with some scraps I had.
Parts needed: 1.5" aluminum round rod
Laser diode, about $4 on ebay. I used just a dot but you could also use a crosshair lens.
CR2032 lithium ion cell
Cell holder for above
Clicky switch from old flashlight
3 grub screws to aid in positioning laser module
Hook-up wire and solder
Sorry I didn't document each step but I'm kind of a novice with machining and you guys could probably machine this a lot better than me. I made it to fit in a 3/4" R8 collet, but in hindsight I shoulda just machined an R8 taper right into it, it would give more clearance in the Z-axis. It probably isn't all that accurate compared to an old fashioned edge finder, but it was fun to make!
