I picked up a selection of adjustable reamers a few years ago. Some are quite large, so I needed a tap wrench that could accommodate the various sizes. I finally got around to it today. The end of the reamer is nearly 1 1/4" square.
Well done Mike, I've certainly never seen a reamer that big.
By the way, did you make that clamp style knurling tool?
I am collecting ideas to make one.
Would you (or have you) shared/posted any info about that?
Thanks.
I wrote it up back in '11. Here it is: http://www.hobby-machinist.com/threads/camjack-knurler.3533/#post-60251
It's your basic clamp-type knurler, but with a cammed lever added that gives a lot of mechanical advantage. I don't usually have to use a wrench to crank in the knurling pressure - fingertips will do. The wheels were from a cheap push-in unit.
