Lantern Chuck
shelly142
Nov 12, 2017
17
The Lantern Chuck shown is not my design. It was modeled after a Lantern Chuck from Model-Engineer in the UK which in turn may have originated from information gleaned from Tubal Cain’s Book, “Work holding in the Lathe”.
There were no drawings for this tool only two photos’ showing a general layout of the tool. I first started by preparing a CAD drawing to determine the general proportions and size of the chuck.
There are two differences in the originators version and the one that I completed. First mine has a 1” diameter shank on the arbor to mount it in a 5C collet, on the original the arbor is married which looks to be a 3C collet. I wanted a more positive method of driving the fasteners to be modified so I incorporated a ¼” hex socket which will accept most all driver bits, phillips, hex, torx, etc. The two main portions of the tool are machined from 1018 CRS Hex and Rod with brass being used for the nose bushings.
This tool is probably more useful for the model builder to more precisely modify screws than for the average hobby machinist. I guess one could continue to use a hacksaw, grinder and file to shorten and modify fasteners. This version will handle fasteners from #6 up to ¼” diameter. In the future I plan on making are larger version to manage fasteners of 5/16” and up but once again will have to start with a CAD drawing to determine the appropriate size for the tool.288408288409288410288411288412
Rootpass, thanks for the positive comments. It was a lot of fun to machine and works great. Never thought of the firearms angle and I agree it would probably be useful there as well. Once again thanks.
Looks especially useful for cutting new scope base mounting screws which need to be cut to a very precise length.
Inspiring, gonna make me one for sure.
Thank You one and all for the positive comments. Happy to share ideas and solutions.
You've inspired me. Started drawing one up this aft.
Greg
