i am trying to knurl a 1/4" wide brass rod. Have tried on 34" aluminum as well. I set up on my Grizxly micro lathe but I leave the lathe off and instead hand turn the chuck. I am using the littlemachineshop clamp knurling tool. I am using the light knurls. (I prefer the coarse knurls but they won't work at all.) my method is to place the knurls over the widest part of the rod, clamp down tight enough to grip, turn one rotation and then continue to tighten and turn. Two things keep happening: the tool angles of perpendicular of the rod and the pattern is messy and never that deep.
Any advice on how to do this better is greatly appreciated.
