Knee mill spindle bearing ring question
Suzuki4evr
Sep 29, 2017
2,307
I have replaced my mill spindle bearings recently and I only now noticed that the ring behind te taper bearing on the bottomend of the spindle is moving freely and greas is dripping out sometimes.
Should this ring be able to move freely or should it have a pressfit into the quill or should the bearing hold the ring tight against the sholder? Is it acting as some sort of sealer or just a spacer? Currently there is about 0.20mm clearance between the quill and ring.
I don't see any seize marks in the quill and it measures spoton at 80.00mm. O what would be a suitable grease?
Thank you
Michael.
It's kind of hard to tell from the picture,but is the bearing race fully seated?
Aftet I posted,I took a punch and lightly tapped it to see if it was and it went just a little bit more and that did the trick. The ring is now not moving,so I guess I solved the problem. Thanks for your reply.
